I know theres threads about this all over the internet but I'm pretty much done trying to figure it out, its had a new head gasket, compression is a solid 150psi across all four, swapped in a known good ICM and coil packs, new plugs. I think theres a vac leak somewhere but I can't find it. I say vac leak because if I start it with the IAC unplugged the revs shoot up to 2k and then bounce between 2k and 2.5k...so the IAC is compensating for the leak when its plugged in...only thing I can think of is a crack in the intake man, I had it off when I did the Head gasket so theres a new gasket on there too...what are the chances?
Any input would be fantastic.
also...I have a spare car (Rusted to shit) with a good engine and tranny...how easy is it to swap the whole subframe with everything still attached?
