98 Grand Prix GTP climate control issues! HELP!
Fester33
98 Grand Prix GTP with dual auto climate control. A year ago there was a whining noise from underneath the pass dash then no air (hot or cold) would blow through vents. After the car sat for almost a year I replaced the blower resister and got air flow back (all settings and all vents) but only cool air on driver side and hot air on pass side. I replaced the door actuator (under driver side) and got cold and hot air on the pass side. Still only cool air on driver side. Discovered the a/c doesnt work/kick on either.
Is there a actuator that controls the driver side hot/cold air? I see a diaphram with two small hoses (maybe vacuum) under the driver side dash that go to it. Does that control the drivers side?
Any help would be appreciated!! Thanks
