I have a 98 pontiac sunfire 2.2L automatic. The ERLS fuse keeps blowing. I have found a digram that lists: evap solenoid, evap purge valve, transaxle (TCC valve, 1-2 shift solenoid, 2-3 shift solenoid)
I have unhooked both the EVAP items, and the ERLS fuse still blows, so its must be one of the three transmission related items. The fuse blows the moment I turn the ignition on...
So my question is, does that narrow it down on which of the transmission items it is?
I would assume that would rule out the 1-2 shift and the 2-3 shift solenoids, because, the car is just sitting in park, not running, all I do is turn the key to the on position when it blows the fuse.
I am guessing it must be the TCC valve or a short? but I cant know for sure, because maybe the shift valves are supposed to reset or something when you first turn the car on. Any help is appreciated.
I used the following diagram:
