ahhhhh check you anti freeze{coolant},then check your oil dip stick make sure it isnt contaminated with coolant. It should be nice oil no milky color,add fluid and try your heat again.. best of luck, hope you didnt hurt the engine
Your intake gaskets might have failed. Check your oil ASAP!!!!! Drain it if there is any milky color to it, that means there is antifreeze / coolant in the oil. Put new oil in it and hae the intake gaskets checked.
If your heater core went bad, chances are you would have smelled a sweet smell with the heat on and the windshield usually fogs up when the defroster is on.
