99, every light is on except engine, keeps resetting?
ethanapplegate18
on the way home it started doing this, my battery and rpm gauge will reset everytime i let off the gas, shift, hit the break, let off break. the lights on my dash are all on, sometimes they don't all show..sometimes they do, my check engine light hasn't been showing though.
i have tried disconnecting the battery for 20 minutes, also i checked all the fuses. also it will beep when it resets, like when you open the drivers door with the key in ignition. i did have a sub and amp hooked up, im not sure if this had something to do with it or not, but they had been hooked up for a few months. thanks for any help. im tired of having car problems.
