99 GA SE high pitched noise and slight vibration when turning left
Navyguns
99 Grand Am SE, 2.4L. After driving 20+ miles, there is occasionally a fairly loud noise coming from the front passenger side accompanied with a noticeable vibration in the steering wheel when turning slightly to the left. Does not happen when turning to the right. This is intermittent and only happens after driving for a while. Brake pads and rotors are new. Wheel rocking test for bearing play shows solid bearings.
