I will try to make this short. Was coming home from vacation when the pass. side started making a noise. Thought at first it was the cv joints so I figured I would still make it home. Well the noise got worse going through Omaha at rush hour so I kept going. Wasn't gonna stop if I had to there.
Got about 10 miles then it sounded like a helicopter was in the van. That low tone whop whop whop of the blades sound. I stopped and saw nothing. Slight vibration in the van with the loud noise. Got 4 miles and the front pass. shook real bad. Almost wreck from the semis around. Stopped and didn't see anything at that point. Drove it on the shoulder to get up a ramp and the pass. tire came off. I didn't notice there were three missing a second ago. It took all five studs off. So I figured the bearing went.
So in tearing this all apart I noticed I can turn the front wheels by hand. Like the tranny was in neutral but it was still in park. I started the motor and put it in drive. Pass side turns but now I can not spin the drivers side. In neutral the pass side still spins.
Now my questions. I can not get the spinal/hub assembly off the half shaft. Any idea to help. I destroyed two 3 jaw pullers trying to get it off. Even put the nut back on and hit it several times with a sledge. Not budging.
Is my tranny shot? The ABS and TCS lights are on. Any help would be greatly appreciated in the biggest way.
Jeremy
Jeremy
