I pulled the relays out of the fuse box beside motor, because i was going to staight wire the fan , i touched each one ,but it started running without switch on, so i rerouted it to the fuse box in car,after that, i drove the car and it would not shift to second, it just stayed in first gear, and the abs light ome on, plus the ets light wouldnt come on no more ,plus brake light is on? Ther is no fuse or relay marked for the transmission, i checked, is there a hidden relay somewhere on the car? Or do you think i shorted the shift soleniod?
