99 transport power unlock (without remote)
  • Thread starter Thread starter Aresti
A
Aresti
I have a 99 transport. 1) When I move gear to Drive doors lock. 2) When I use the inside button to power unlock the doors does not function (stay closed). 3) To unlock the doors elctrically I have to turn the ignition off 4) Also, engine running shift into Park posission it should unlock the doors automativcally does not funtion as well. Any suggestions to solve the problem please.
Have a look in your owners manual, I believe there is an enable/ disable function you may need to play with..... good luck.
