Hi,
New member.. I recently bought a 2007 Montana SV6 extended.
The a/c did not work when I bought it. I thought it probably a compressor or something simple. But, what we have is the following.
Freon - Low side 40-45 psi
High side 200 - 220
No leaks.. Compressor is running once you turn on the a/c. But only blows regular air.
One more thing. There is a very noticeable vacuum suction as soon as you turn on the a/c. It stays on the whole time. If you shut the car with the a/c running, the sound will continue for another 3-4 sec and fade slowly.
I went to the dealership and got pictures of the diagram for the evaporator box and the 3 different doors that open and close. They all say that they are electric motors for the doors that open and close for a/c, vent and temp.
what could be the noise. The only suggestions I got so far is there is a heat/ exchange issue and needs to be cleared. It's either evaporator core or condenser. I also found a lot of rust by the floor. I am planning to open the minimum I needed to get the problem fixed. The worst is the whole dash have to come off... Any suggestions are very helpful. Today was a very hot day in Toronto.
thanks,
Desmond.
High side 200 - 220
thanks,
Desmond.
