My wiring was cut at the back of the ac compressor, I have a green and a black wire to the clutch plug, and a green/white stripe going to I assume the high pressure switch (a single pole connector) and a black that was cut that I think should have gone to the low pressure switch but the low pressure switches I see are all two wire. Am I missing a wire or do I have to hook up only one wire?
