ABS/Brake light
BigRob
I put a abs on my 02 grand am. The light on the dash is still on also the brake light on the dash is also on. I have brakes an the e brake is off. I unhooked the battery for awhile then hooked it back up. Still on the dash.
I also have a trac off light on with service vehicle soon light on. The car has been in the air on jack stands for a few weeks. Dont kno if that would turn the trac off light on. I didnt touch anythig to do with the trac on the car just the abs an brake lines plus the air filter I took out to get the abs. Any clue what it could be?
a bad wheel sensor or the harness going to the sensor
Would the service vehicle soon light come on with the trac off light
You have to have the code read at autozone or similar store that does it at no charge
