Abs brakes
FYSHAWK1
Oshawa
I am new to this forum and it seems i will be in and out of here a lot as i bought a 2006 Torrent i have owned it for just over a month and already had to have front caliper drivers side replaced and there was a vac hose off at rear of engine the caliper i didn't have to pay for but the vac hose i did 158.00 dollars to get it diagnosed and fixed
Now i have a problem when braking it brakes fine when driving along until it slows down then grinding and the pedal starts pumping and a hum i can hear from front to back that is there for a while any ideas on what this can be
grinding usually means one of the brakes is over due for maintenance and you have metal on metal
