abs light
dmw521
no signal to Rt front wheel speed sensor, need wire diagram, and any suggestions
have you looked at the wire connection at the sensor?
have you used an ohmmeter on the sensor?
the connector
the connector is clean, this is the second sensor I have installed, I need a wire diagram to determine which wire goes to the right speed sensor from the abs unit, location of connectors, common problems, the connector under the carpet already has one wire jumped from a previous repair
what year is the vehicle?
