Aftermarket Stereo won't turn on!!!!!
epicboy75
The aftermarket stereo that I installed in my 2007 Pontiac Montana SV6 won't power on! The connections are made but when I plug the harness in the stock on and turn the ignition on the screen won't flicker on. Don't know what to do please help. The aftermarket stereo is a Jenson VX3022 Double-din
1. Is this a new stereo or a used one?
2. Did you disconnect the vehicle battery before starting the installation?
3. Did you check for a any blown fuses?
4. Did it come with instructions including a wiring diagram?
http://www.jensenmobile.com/docs/common/VX3022/VX3022_IM.pdf
5. Did you call the Jensen support line on page 3 of the manual?
