To answer your question no,but I can tell you this much in the summer time on a very hot day with the windows up I got in the van start it up and the air bag light came on and what I did was push on the steering wheel where the air bag is and kind of push everything back in towards the middle cause everything seemed swollen from the heat and after the next start/stop cycle the light went out. I believe there is a pressure switch behind the deflated bag that has to be satisfied along with other sensors/switches.One area to check is the wires/connections under the seats they can be damaged easily from toys/garbage ect... Good luck and keep us posted
