all Service lights on abs,srs,airbags,brake,stabilatrac
COZMIKBLU
Iam workin on a 07 torrent and all the service light except check engine light:s are on ABS SRS or Airbags the traction control an the stabiltrac also the brake light pops on and off .I had the torrent scaned an I got a slew of code.So of the code I have been able to look them up.here are all the codes I got Airbag codes are c0500,c0561,c0451,c0501, I only wrote down part of the codes an those may not be correct c0500,and c0561 the other codes or could be c0545 c0550 or c0045 an coo45.I now one of the codes said the abs computer cant commnicate or loss of commtication.I got a SRS code B0081 dont know what this one is.I got a vo131 code thats loss of comication with power steering but the power steer works fine.an I got a B0074 and this code also have to do wit the pass side ocupent module. I was going start with getting the airbag ecm reset or reprogramed an see where that puts me and go from there.If anyone has any suggestion it would be great:confused: the customer stated tha all these light came on at the same time
I woulds suspect a BCM issue, bad ground, corroded connector,etc.
