One night my car died in the middle of the road, checked to see if i was getting spark and i was only getting spark from one coil pack. so i switched around my coil packs and i was still only getting spark from one position on the ICM no matter what coil pack i put there. So i thought it was the ICM its self so i had my ICM tested at autozone. Took my ICM in had it tested, failed the 1st test on one test. retested 6 other times and it passed every time after that. so i said screw it and bought a new ICM from autozone and a crank shaft sensor. I put the new ICM/Crank shaft sensor in and i got no spark from no coil packs no matter how i moved them around. I put my old ICM back in to see if it was just my Crank shaft sensor and it wasnt, still same spark in the same position no matter how i moved my coils around. Any help please!!!!!!!
Nope sprayed fuel direct into my engin, Plus only one of my coil pack is working, my fireing order should set off all of them, all 6 should fire at different times but only get two to spark when cranking it over, but it wont start. as i said i also changed ICMs and got no spark from the new one
