Steve Baker
- Apr 7, 2014
2003 Pontiac Montana: I need to know the "nominal" amperage between the wire that attaches to the under-hood fuse block and the fuse block itself. I installed a new battery about a year ago and it seems to go dead if I don't drive the vehicle often.
If I remove the fuse (number 29 in the diagram) that goes to the radio, Driver information display, Heater A/C control, rear side door actuator motors, Remote control door lock receiver, Security indicator lamp, and theft deterrent shock sensor... the battery will not drain and the van will start as usual.
There seems to be a 1.3 - 1.4 amp current between the wire and block, going down to 0.0 when the fuse is removed.
The Left side door motor seems to have stopped, along with the driver's side seat position motor. Could any one of these motors be "burned or shorted out", causing a higher than normal load? Thank you.
Steve Baker
Steve Baker
