Any gas saving tips for a 2002 pontiac grand am...
  • Thread starter Thread starter Anthony N
A
Anthony N
...SE1??? Besides the obvious ones of course. I even looked at the tornado fuel saver and the cyclone, but I've heard that they are worthless. Any tips will be appreciated :)
Air up the tires, put synthetic or parasynthetic oil in the engine next oil change, clean air filter (reusable one is preffered) and practice the egg-celerator technique of driving where you accelerate as if you have an egg between the pedal and your foot, and then ease off the gas early prior to stopping. Try and maintain a constant speed rather than speed up, slow down, speed up etc..... also try driving less one day a week.
Subject: Fw: Tips on Pumping Gas
TIPS ON PUMPING GAS
I don't know what you guys are paying for gasoline.... but here in California
we are also paying higher, up to $3.50 per gallon. But my line of work is in
petroleum for about 31 years now, so here are some tricks to get more of your
money's worth for every gallon..
Here at the Kinder Morgan Pipeline where I work in San Jose , CA we deliver
about 4 million gallons in a 24-hour period thru the pipeline. One day is
diesel the next day is jet fuel, and gasoline, regular and premium grades. We
have 34-storage tanks here with a total capacity of 16,800,000 gallons.
Only buy or fill up your car or truck in the early morning when the ground
tem! peratur e is still cold. Remember that all service stations have their
storage tanks buried below ground. The colder the ground the more dense the
gasoline, when it gets warmer gasoline expands, so buying in the afternoon or
in the evening....your gallon is not exactly a gallon. In the petroleum
business, the specific gravity and the temperature of the gasoline, diesel and
jet fuel, ethanol and other petroleum products plays an important role.
A 1-degree rise in temperature is a big deal for this business. But the service
stations do not have temperature compensation at the pumps.
When you're filling up do not squeeze the trigger of the nozzle to a fast mode.
If you look you will see that the trigger has three (3)stages: low, middle, and
high. In slow mode you should be pumping on low speed, thereby minimizing the
vapors that are created while you are pumping. All hoses at the pump have a
vapor return. If you are pumping on the! fast r ate, some other liquid that goes
to your tank becomes vapor. Those vapors are being sucked up and back into the
underground storage tank so you're getting less worth for your money.
One of the most important tips is to fill up when your gas tank is HALF FULL or
HALF EMPTY. The reason for this is, the more gas you have in your tank the less
air occupying its empty space. Gasoline evaporates faster than you can imagine.
Gasoline storage tanks have an internal floating roof. This roof serves as zero
clearance be tween the gas and the atmosphere, so it minimizes the evaporation.
Unlike service stations, here where I work, every truck that we load is
temperature compensated so that every gallon is actually the exact amount.
Another reminder, if there is a gasoline truck pumping in to the storage tanks
when you stop to buy gas, DO NOT fill up--most likely the gasoline is being
stirred up as the gas is being delivered, and you! might pick up some f the dirt
that normally settles on the bottom. Hope this will help you get the most value
for your money.
DO SHARE THESE TIPS WITH OTHERS!
WHERE TO BUY USA GAS, THIS IS VERY IMPORTANT TO KNOW. READ ON
Gas rationing in the 80's worked even though we grumbled about it. It might even
be good for us! The Saudis are boycotting American goods. We should return the
favor.
An interesting thought is to boycott their GAS.
Every time you fill up the car, you can avoid putting more money into the
coffers of Saudi Arabia. Just buy from gas companies that don't import their
oil from the Saudis.
Nothing is more frustrating than the feeling that every time I fill-up the tank,
I am sending my money to people who are trying to kill me, my family, and my
friends.
I th! ought i t might be interesting for you to know which oil companies are the
best to buy gas from and which major companies import Middle Eastern oil.
These companies import Middle Eastern oil:
Shell........................... 205,742,000 barrels
Chevron/Texaco......... 144,332,000 barrels
Exxon /Mobil............... 130,082,000 barrels
Marathon/Speedway... 117,740,000 barrels
Amoco........................ ....62,231,000 barrels
Citgo gas is from South America, from a Dictator who hates Americans. If you do
the math at $30/barrel, these imports amount to over $18 BILLION! (oil is now
$90 - $100 a barrel
Here are some large companies that do not import Middle Eastern oil:
Sunoco..................0 barrels
Conoco..................0 barrels
Sinclair.................0 barrels
B P/Phillips............0 barrels
Hess.......................0 barrels
ARC0.................! ...0 ba rrels
If you go to Sunoco.com, you will get a list of the station locations near you.
All of this information is available from the Department of Energy and each is
required to state where they get their oil and how much they are importing.
But to have an impact, we need to reach literally millions of gas
buyer s. It's really simple to do.
Now, don't wimp out at this point.... keep reading and I'll explain how simple
it is to reach millions of people!!
Get a fram air and oil filter. They gave me around 40 more miles per tank. I also have a tornado and it actually does help. good luck
