Approximately how much will it cost to repair a busted brake line on my
Mark H.
1998 Pontiac Sunfire? Approximately how much will it cost to repair a busted brake line on my 1998 Pontiac Sunfire?
geenerally 40 dollars per line or close call oreilly auto parts or auto zone hbave them give you an exact quote
20.00 bucks if you measure your old one then get another one and change it then bleed your brakes. If you have someone else do it, about a 100 dollar bill.
do it yourself ! all you need is a brake line and some brake fluid. about 15 or 20 bucks.
Where is it 'busted'? Is in in the metal line? Are you confident in flaring(its not too bad)? Do you have a flare nut wrench set?
