ATF -TYPE for a 66 Le Mans 326
Somerville
Checking the ATF - the stick shows use only AQ-ATF
Is this still available or, do you know what ATF is comparable?
Thanks!
Dexron III type fluid is backward compatible to type AQ. Some manufacturers market a Dexron/Merc fluid. Look at the bottle to make sure it covers Dexron III and back.
When I picked some up yesterday that is what parts house recommended but at times they could be mistaken. Thank You!
