Pontiachead
- Sep 15, 2011
First off hello and a quick run down of what I have going. I purchased a 99 Montana with 105k miles in great condition(70 year old lady 1 owner). I want to let known what I have done to get this van nearly 100% mechanically right, and possibly receive a little help as well. I opened up with addressing the erratic fuel guage by dropping the tank and replacing the pump/sending unit with the unit from 1A Auto....Hell of a job and now that prob is fixed. Then I replaced a rusty Window regulator on the drivers side to restore speed on my window...but it still gets slow towards the top due to a bind I believe. In addition, I had probs with my rear brake/running lights going out...found burned out modules and replaced with new prob solved(the connection was melted).
A week ago it was suspension time to address the clunk I hear when backing up slowly and hitting bumps at a low speed...outer tie rods shot. Replaced them and realized inners were shot...replaced them, Note: You must use KD 3312 tool for an oem 2 in 1 won't work on ours...I found out the hard way. Our inner tie rod socket is a complex one requiring an extra special tool. Anyways, all new inner/outer tie rods and the front end is tight and feels great, KYB GR-2's and rear struts/shocks on the way(front 2 kyb's $98 shipped off ebay). Now, it appears the intake gasket has been replaced and upgraded along the way...so I still run dexcool(flushed and installed new water pump, ater seeing slight leak..new water pump fixed the prob) and my cooling system has been perfect. Had wipers not parking...Lubed the wiper mechansim under dash and cleaned...prob solved. Also pay attention to your sway bar bushings...had a lil popping their...inside spacer piece between the middle bushings was corroded and weak(new Moogs installed cheap off Ebay$25). And no I'm not an Ebay rep lol...I shop very hard for the best deals tho.
So...my only issue now is an ABS light...I tried to scan it with my Snap On scanner but it says "brake module not responding"...I had Autozone scan it and it said the same thing, different cheaper scanner. Would this be a failed module? Or the notorious wheel bearing failure? I've done a ton of research on this van because it is my family vehicle that transports my 2 month old boy and wife...my goal is to make it like new as much as possible. If any of you need any help let me know I've done alot on this vehicle. I've always been a die hard Pontiac guy as my first car was a 1996 redbird, second was 1999 blackbird...I typed all of this because I spent so much time looking and searching for these answers and maybe I can save someone alot of time...Thanks in advance and hope to hear some ideas...~Mike
