Hi all, my Fiero (1986 2.8 GT Auto) battery was flat this morning, so I jump started it off my MG. It fired up fine.
Problem I've been having for a while is when I first start the car, the volt meter shows low (9V I think). Then when I rev the car hard, the needle jumps up to 13.5 - 14 Volts then stays there, if I turn the car off and start it again, the needle goes down to (I think) 9V again.
I assume that when I start the car, the alternator is not charging the battery, but then when I rev the car, the alternator cuts in and then continues to charge.
The car has been idling high at 1200 revs since I got it 5 months ago, I've noticed today though, the car settled to 800 revs when I left it with the volt meter low i.e whilst the alternator wasn't charging, as soon as I revved the car, the volt meter went up to 14 volts and the idle speed went back to 1200 revs and stayed there.
I haven't got a clue when the alternator should kick in etc. If anyone has any insight or knowledge that may help me to diagnose the problem I would appreciate it.
By the way I put the battery off my MG onto the Fiero and started it, the volt meter behaved the same, so although the battery was flat this morning, I don't think that is the problem.
