Did you check the other door switches to see if they are broken. I see no BCM for your car but you can check the fuse boxes in your car to confirm that. If you have a BCM it would use a fuse.
no I didn't check them. but the wire diagram shows 1 ground wire for the other 3 doors but I don't know where it's grounded to it show under pass seat I can't find it.
