bleed abs without pump
I just finished replacing a brake line on my 2003 Aztek. to bleed ABS with out pump I attached a 3 foot piece of plastic tubing to the bleeder nipple farthest down the line from the master cylinder. put the end of the tubing in a gallon jug. opened the bleeder nipple and filled the brake reservoir with fluid-- with the engine off or on pump the brake pedal. I found 20 pumps will just about empty the reservoir-- DO NOT ALLOW THE RESERVOIR to run dry-- refill it with fluid- 20 pumps again, and again, and again. I pumped what was about the equivalent of 3 quarts of fluid through the system. ( I just recycled the fluid that was collected in the jug. you may want to discard the first fluid that come through if it is discolored)) be careful not to allow any air to back up in your plastic tubing to the bleeder nipple. after I had pumped fluid through the system repeatedly I closed the bleeder nipple with out removing the tubing or allowing any air to back up into the nipple. then removed the tubing, put the tire back on and went up and down the drive way a couple of times to make sure I was good to go-- then around the block---- seems to have worked fine- On the cheap~~
