From my last post, I mentioned how I had replaced the master cylinder on my 2001 Pontiac Aztec. Had lots of trouble finding an exact match for master cylinder and the one I got looked identical, except for the threaded bore size where the brake lines go in. After getting adapters and installing it, brakes are worse than ever. Before they were soft and squishy, and when you’re at a light, the pedal would slowly go to the floor making me think there were some leaks in the master cylinder. Now you only get any break in the last 2 inches before it hits the floor. I had to remove one of the lines from the ABS block to bend the brake line so it would clear with the new adapter on. So I figured I might’ve gotten some air in the ABS Module. Used almost a full quart of brake fluid carefully bleeding every wheel today starting with the furthest. Did see air come out of the passenger side, rear and front. Pumped through more brake fluid till there were no bubbles, figured I’d gotten it. But now I barely have any brakes at all. Thoughts? I took it to AutoZone and they scanned it and got three codes. c0550 -ecu Malfunction, code C0035 will speed sensor, circuit malfunction and code C0896 - device voltage range /performance. Sorry this is so long, but any advice would be appreciated. Thanks!
