brakes on my 02 pontiac aztek are bad?
  • Thread starter Thread starter Dave M
D
Dave M
i just changed the brake caliper, i put all bolts back on, i used caliper lube, every bolt is tight and correctly placed. i bled the brake lines and the brakes tightened up really good. i proceeded to test drive my car, but when i started the car the brake pedal immediately lost pressure and went right to the floor. it can brake but only if i press the pedal all the way down and when i lift it up a centimeter, the car moves. what is happening???
assuming you have no leaks, how did you go about bleeding the brakes, it sounds like you have air in the line or the master cylinder may have failed.
