I replaced all the drum hardware and wheel cylinders and can’t get any fluid to bleed out. Maybe the master cylinder is stuck or valve bad. I can pump the pedal freely to the floor but nothing coming out.
Find the correct size bolt where the lines connect to the master and disconnect lines and install bolts. If pedal still goes to floor master needs to be rebuilt or replaced but not the booster.
Trying to figure out which master cylinder to order. The one I took off is delco stamped j256 and the other side stamped 452310. I have drums all around
