TOG1937
Member
- Feb 4, 2020
Found the original build sheet for our 1966 Catalina Convertible atop the fuel tank. A bit tuckered after almost 60 years but better than 50% readable, looks like one of the Dead Sea Scrolls. Also found a second build sheet for a wagon, VIN 25235. You have that car? I'll send you the build sheet. Was able to use some of the info from the wagon's build sheet to decode part of what is illegible on our build sheet.
1966 Catalina Convertible build sheet found on top of fuel tank
1 JOB SEQUENCE NUMBER: BL 4834
10 SCHED. No. DATE: 07 06-30
11 FRAME: HB
12 KNUCK? SA
13 REAR SPRING XP?
14 FRT SPRING: ZB?
15 REAR SHOCK: LB
16 FRT SHOCK: JP
25 MODEL: 25267
26 TOP: 4
27 ENG: YC
28 TRANS: PB
30 ALTER: XA
31 ALTER PULLY: blank?
32 STARTER?: AE
33 FUEL PUMP
34
35 CRANK PULLEY
29 blank
41 TRIM: 516
42 COLOR: C4 A
43 WHEELS: H
44 RADIATOR: PG
45 RADIATOR UPR. HOSE: NA
46 BATT: 55
47 BATT POS CABLE: NU
52 ENGINE HARNESS
57 SPEC. ORD: blank
58 BODY FRT. RR HARN. : AEBR
59 BODY LAMP HARNESS: ***M
60 BODY WR. HARNESS: *****
61 WR CV HARN: *
62 LP. HARNESS: PB? PH?
63 CONSOLE HARNESS: **
64 INSTR CLUSTER: YO
66 WIPER MOTOR
67 STEERING COLUMN
74 blank
75 H/LINER: **
76 W/HOSE blank
77 SHELF TRIM: **
78 SEAT ADJUSTER: AV**
79 PAD FRT. BACK: **
80 PAD FRT. CUSHION: AQ
81 PAD REAR BACK: DH
83 CARPET FRONT
84 CARPER REAR
89
% A39 DLX F&R BELTS ??3 INSUL SHR PNL J50 POWER BRAKES
$B24 W/S MLDG BRT ??? INS NG TLT MR? M40 TURBO-HYDRA
% B50 FRT SEAT PAD ??? 07S RER RV MR N30 DELUXE STEERING WHL
% D34 VISUR VAN MIR N40 POWER STEERING
?35 HD FRAME
90 PROTECT-O-PLATE blank TRIM: 516 PAINT: C4 VEHICLE: 25262 NUMBER: 14 CARB blank ENGINE blank
91 ORDER NUMBER: 25439
92 ZONE: 04
93 DEALER: 223
94 CLASS: A
95 TAG blank
96 ZONE? Blank
97 DEALER blank
98 CHARGED TO:
KING PONTIAC INC
16200 S FREDERICK AV
GAITHESBURG MD
11 FRAME: HB
12 KNUCK? SA
13 REAR SPRING XP?
14 FRT SPRING: ZB?
15 REAR SHOCK: LB
16 FRT SHOCK: JP
25 MODEL: 25267
26 TOP: 4
27 ENG: YC
28 TRANS: PB
30 ALTER: XA
32 STARTER?: AE
33 FUEL PUMP
34
35 CRANK PULLEY
29 blank
41 TRIM: 516
42 COLOR: C4 A
43 WHEELS: H
44 RADIATOR: PG
46 BATT: 55
52 ENGINE HARNESS
57 SPEC. ORD: blank
61 WR CV HARN: *
66 WIPER MOTOR
67 STEERING COLUMN
74 blank
75 H/LINER: **
76 W/HOSE blank
77 SHELF TRIM: **
83 CARPET FRONT
84 CARPER REAR
89
?35 HD FRAME
92 ZONE: 04
93 DEALER: 223
94 CLASS: A
95 TAG blank
96 ZONE? Blank
97 DEALER blank
98 CHARGED TO:
KING PONTIAC INC
GAITHESBURG MD
