I took my abs pump out of my grand am...I went to drive it last night an the brake went to the floor...I bleed the brakes...I got them feeling new...Then next morning the same thing...Its holding fluid...Im lost ty
Not sure how or why you did that and still expect the brakes to work but you are sucking air into the system if the pedal improves with bleeding and you see air coming out when bleeding.
I need a new abs pump also need a car...lol...From the master cylinder you have two lines going to the abs pump...Four line coming out of the abs pump to the wheels...I took the abs pump out...Now I have two lines coming from the master cylinder with a splitter on one line for the front an the other line with a splitter for the back...I dont see how air would get in the system...Only thing that I can think of is the rubber in the cap on the master...Even with the abs pump the rubber an cap are still in play...I kno this is a run on but ty...
