I am trying to help a neighbor with her 2006 Pontiac Montana. She says that she has had a couple of instances when she turns (right turn only??) the van, the ABS are triggered and a Stability System warning message comes up. She brought it to the dealer and this is what the estimate said:
"c0196 high resistance in yaw rate sensor wiring system needs to be rewired from electronic brake control module to yaw rate sensor and from electronic brake control module to powertrain control module"
The estimate was for $1700, which she can't afford.
I am thinking the issue is with a connection or a wire that that has been partially cut- possibly around the air filter housing.
My questions:
Does anyone have an idea of what wire(s) I would be looking for?
Is there a wiring schematic that at least narrows down the color of the wires or the pin number in the conector?
Any other ideas?
My questions:
Any other ideas?
