As the wheel spins, the wheel speed sensor produces an Alternating Current (AC) signal. The Electronic Brake Control Module (EBCM) uses the frequency of
So what have you done so far to determine if any of these causes is your issue?
Faulty Rear Speed Sensor
Rear Speed Sensor harness is open or shorted
Rear Speed Sensor circuit poor electrical connection
Faulty EBCM
Cleaned all and visual inspection of connectors and wiring harnesses. Checked voltages. Assuming all is correct now I lead to believe it’s da wheel hub assemblies
