i can tell you ,but you,d be better off with a haynes repair manual on this car,,you can find them at any advance auto parts store,,is not a bad job though,you remove the battery cable,,then remove the wires from the starter,,then remove the bolts that hold it on,,reverse this to put it back on,,you really need a manual on this one,,it will help you with this job,and more to come in the future,,good luck with it,hope this help,s.happy new years.
first disconect the positive cable of the battery then jack youre car go under youre car find the alternator disconect the wires of the alternator take off two bolts and remove the alternator replace in reverse
