Hey guys,
I have a 2001 sunfire, 2.2L with manual transmission. I had to replace the transmission, so i just took the whole engine out to do it. I put it back and and somehow mixed up some wires and cant figure out how to rewire the starter. (simple, i know) I remember taking off three wires (small signal wire, 2 large wires from batt and alt). However, when i went to put it back on, there was 4 wires, the extra on a large wire coming from the starter relay, where the signal wire comes from.
I have been searching for a wiring diagram to no avail. The haynes manual wiring diagram does not match my system ( i have a relay..) and is of no use.
if someone has a similar car, would you be able to post some pictures of the starter, relay, and its wiring to the forum so I could look at it? It would be a huge help. the relay is mounted between the radiator and enginer, and the starter is mounted on the engine near the bottom of the radiator.
Thanks, Bill
Thanks, Bill
