Can you move the sidescoops of the Pontiac Fiero beneath the car?
kyleryantoth
Several reasons to ask this. On the sides of the car it is effectively forced air induction, but I believe it would have more airflow beneath the car because of down-force pressure between the ground and the car. Also at higher speeds wouldn't a (pair of) scoop(s) create down-force thus increasing road grip? Furthermore could this be used as a solution for v-8 overheating? Make a full width scoop to send cool air upwards into the engine bay? I am not talking about a giant scoop that would scrape the ground but a wide thin one (or two). The only issue I could foresee would be road debris and water.
However if you had a V8 or 3800SC built just for track use it shouldn't be an issue.
