1987 Sunbird GT non turbo, when cold engine, and accelerating, the car jerks back/forth, struggling at about 3000 -4000 rpm's. manual transmission. But after say, 5 minutes, as it warms up, problem goes away. Recent cylinder head replaced, but leaking oil at camshaft carrier, and blue smoke coming out of tail pipe. Head gasket blew with coolant spewing everywhere, before head gasket replacement.
I dont think the oil burning should be the cause, do you? Maybe head gasket was not put on right and coolant is seeping into cylinders when car is shut off, sits overnight, and upon startup car runs rough because of coolant mixing with fuel(?). But shouldnt that be spit out immediately, and not for 5 minutes?
I checked the OHMS on both temp sensor and air temp sensor inside air filter housing, both checked out OK.
Thanks.
Thanks.
