Motorbreah
- Jul 8, 2013
So, I just had the trans out for the past few weeks and was doing some major work to it. As you all may know the tyranny and engine come out together on the cradle (out the bottom I might add). Well after painfully reinstalling everything I have an issue with it not starting. I suspect the Neutral Safety switch is not aligned properly. But it is an 03 and has the "internal" range selector which GM claims doesn't need adjustment. My other theory is that the starter is not wired correctly. If yall wouldn't mind taking a picture of the starter and wiring as it is when installed, it may help me wire mine correctly.
Symptoms include: Power to vehicle, Battery reads 12.6 volts and is actually brand new. Hot starter wire confirmed to have current. Fuses checked good. Key is turned to ignition, dash goes black as it should when started is engaged. No audible action is heard from starter. Engine does not rotate.
Using All-Data I pulled up the wiring diagrams, but they don't actually match what i'm seeing underneath the hood and are therefore unreliable it seems.
Thanks guys, hopefully looking forward to hearing from somebody before too long.
