Maxxthedog
Hi Gang,
I have search this (and other) sites and seen similar issues to mine but not quite the same.
1972, 350 2bbl, 350 auto, all stock.
New, manual stock fuel pump.
Carb was rebuild.
After driving car and it is how (about 30 minutes or so), the engine will flood and die. I was finally able to get it to do this in the garage with the air cleaner off. I looked down the carb and gas as pouring into the carb. It only does this when hot.
I have seen this issue on a hot restart, but never while driving down the road.
I have seen a recommendation to check my fuel pressure. How do I do that? Just put a hose on the end of the fuel line that does to the carb and crank the engine?
For those of you that have a psi gauge in-line, how did you do it? I have one solid metal line that runs from the fuel pump to the carb.
Thanks
Carb was rebuild.
Thanks
