Sebastian S.
I am currently working on the carburetor and ignition settings for better acceleration and smooth idle.
Ignition system:
- Pertronix 1183N6 "Ignitor" Ignition Module for Delco, early 8 Cyl with 6v Negative Ground
Distributor:
With factory settings according to service manual
- Static advance timing of 6° before UDC --> that means, that you have to add 6° to all measurements in order to get the full advance reading before UDC!
The idle speed screw is limited to reach 1500 RPM max. Currently, I don't have a solution how to run the engine faster + measure at the same time. Any suggestions here?
According to the data and my measurements:
1st. testdrive with 6° static advance (0° according to service manual) and 585 RPM idle:
Idle mixture seems not to be perfect + engine is too retarded at higher RPMs. Idle mixture maybe too rich?
Adjustments afterwards:
2nd. testdrive with 10° static advance and 550 RPM idle:
Idle mixture seems to be good for the static advance timing. Engine shows some hesitation at higher RPM under load – still 2-4° too retarded?
Nothing so far.
...to be continued.
Ignition system:
Distributor:
- Original Delco distributor
- Everything has been thoroughly cleaned and greased / oiled
- HARDI fuel pump type 1776 with fuel delivery capacity of 50-60l/h at 0,20-0,28 bar, 6V / 3A
- Fuel pump safety controller PN 12003 by Revolution Electronics, with 3-sec priming and auto-off in case of missing ignition signals (=motor off)
| RPM | Total advance in ° (tolerance +0°/-4°) | Measured total advance in ° | Vacuum advance + total advance in ° |
500 | 2 | 0 | 0 |
800 | 4 | 2 | 7,5 |
1000 | 5,75 | 4 | 15 |
1200 | 7 | 5,5 | 21 |
1500 | 8,75 | 7 | 27 |
1600 | 10 | ||
2000 | 12,5 | ||
2400 | 15 | ||
2800 | 16 | ||
3200 | 18 | ||
3600 | 21,5 | ||
4000 | 25 | ||
4200 | 27 |
- It looks like mechanical advance works fine up to 1500 RPM.
- Vacuum advance kicks in at about 680-700 RPM and looks good too.
- Starts up fine.
- Engine idles ok, but every 3-5 seconds, there is a putt sound and the engine block shivers a little. Misfire?
- RPM meter shows some slow rolling between 472-485.
- Above 40 mph the engine does hesitate under load - max speed without hesitation is about 50 mph.
- Adjusted distributor to 4° static advance timing (6°+4° = 10° UDC) --> when turning distributor counter clockwise to achieve new setting, RPM increased by 15-20 RPM in idle.
- Adjusted both idle mixture screws until engine ran as fast as possible (leaner mixture!)
- Starts up fine.
- Engine idles good, stable at 550 RPM (+- 3 RPM).
- On high RPMs, engine does hesitate slightly under load. Max speed without hesitation is about 65-70 mph.
Nothing so far.
...to be continued.
