i pulled off the upper hose off the engine and no thermostat. so it is in another place is it easy to change and can i do it. and where abouts is it. any help would be a life saver. thank you
The Thermostat is located at the end of your intake manifold. You will see a large "J" shaped pipe coming into the thermostat housing at the bottom. The housing also has 2 smaller hoses coming out the top and the side (and another large, short hose on the other side) 2 Bolts hold in the housing
