1994GrandAm
- Mar 14, 2013
Hi, this is my first post here. My mom has a 1994 Grand Am SE, 4 door, 2.3 SOHC, 82K miles.
I recently put a new water pump on, and of course had to remove the exhaust manifold to get access to it.
One of the two bolts that connect the exhaust pipe to the manifold broke off, and after getting the manifold off, I tried to drill it out, after dulling my drill bits, I just took the manifold to a machine shop to have them get it out.
Note, I never removed the oxygen sensor.
Got the car all put back together, and after a few miles the service engine light came on, is not always on.
The car is getting bad MPG as it drank through a tank of fuel quick, and feels like a misfire.
I took the car to O'Reilly for the free check engine light scan, the guy said cigarette lighter fuse must be out, as his scanner was not working.
So, later that day I decided to pull the spark plugs (I had replaced them about 25K miles ago as it had a misfire, along with the plug wires/coil to plug connecters, whatever they are called) the plugs were pretty carbon fouled.
So, I bought some new AC Delco plugs, took it for a spin, felt kinda better. I did disconnect the battery for at least a hour while changing the plugs, so that should reset the service engine light codes right?
After taking it for about 5-10 miles the service engine light came back on.
Checked the cig lighter fuse, it's fine, took the car to Autozone to have them try, they did not have a scanner for it, and gave me the little jumper key, I tried no flashes of the light.
So, they told me I could buy a scanner for 29.99, but looking on the back it only said it did Camaro and Firebird and other cars for 1994, so I held off.
Next day took it to O'reilly again, different guy, he asked if the light was on right then I said no, it comes and goes, so he did not even wanna hook up his scanner saying the light has to be on to work.
Then he told me I could take it to a shop to have it scanned, and I said that's ok, I figure it out before paying someone.
So, it appears from the manual this 1994 year is at the change from OBD1 to OBD2, and the older years the jumper wire/key between the pins was the way, and 1995 and newer you use a scan tool.
I'm thinking the oxygen sensor got damaged during the removal of the broken off exhaust bolt in the manifold, as this problem started after doing the water pump replacement.
Is there a scanner that will work on this car for sure to see what the code is?
