Checking codes 98 sf 2.2
Mh458
Member
How do you check codes when car won’t start?
You plugged the scan tool into the obd port and turned the key to run?
Did you have a check engine light on before the no start?
No I thought you could check it without a tool
Not with OBD2 which started in 96.
