Clunking in rear
Bruicer
2005 Montana SV6
It started today i'm getting a clunking coming from the rear when i hit any size bumps or cracks in the road anyone else have this happen my visual inspection i couldn't see anything wrong springs,shocks seem okay thought it might have been a broken muffler hanger but they are okay thanks for looking
Hi !
See rear stabilizer bar. They are very common to cause this problem.
You can also raise the rear suspension, but instead of removing the tires, you can get under inspect for leaking shock shafts and broken or loose shock absorbers. Also, inspect the shock bushings.
As well as ...
Thanks sergeimoskva,
I have checked all the bushing can't seem to see anything wrong with them shocks as well but not sure if something in the shock is broken just can't seem to find it and could get expensive starting to change thing out until you find it
I had a noise back there once. Turned out that is was the metal adjusting bracket for the parking brake cable was banging against the cross member/axel. The rubber grommet that was supposed to have been there rotted off. I made a new one out of pipe insulation. No more clunks or bangs.
