tilliepeople
- Aug 24, 2023
I have an extremely loud cluck on my 2006 Montana.
It only occurs when at an almost full stop or when I start to move again.
I have replaced pretty much everything that was even a little loose, but clunk does not go away.
Replaced axle shafts, rotors and pads, wheel bearings, Lower control arms, inner and outer tie rod ends and sway bar links.
I did manage to break the ABS sensor wire on the wheel that makes all the noise though.
I can't keep throwing parts at it although everything I have changed did show wear, but some may have survived a couple years.
I need help diagnosing this problem.
Thank you!
Bill
Thank you!
Bill
