blebs
I have a 96 Sunfire driving me nuts. I have this clunking sound, which seems to happen any time the control arm is forced upwards a tiny bit. It also occurs on starts and stops, but is much more noticeable when you go over a rough spot on a road surface. Took it in to have it looked at, thinking it was the engine cradle, but all they could find wrong were wheel bearing hubs. Replaced those, but the problem continues. It has a new/reman steering gear, new wheel bearing hubs.
I'm thinking it's the control arm bushings. Whatever it is is torque and sudden pitch in road changes. I'm not feeling it in the steering wheel at all, the car doesn't pull one way or the other. I'm baffled at this point. It's getting worse and wanted to make sure it wasn't a safety issue, which they assure me it isn't.
Anyone have the same problem or have any suggestions? I really don't want to take it to another shop since darn few of them around me can be trusted, but when you take something to one that you do trust and they can't find anything wrong other then the wheel bearing hubs, what would you suggest?
