when i put the new clutch in,I do not have the pedal to release the disc from the flywheel,I have 0.60 shims between pressure plate and flywheel to release the clutch,but with this shim,my throwout bearing is running against the pressure plate
according to this there is only one www.fierostore.com/Product/Browse.aspx?d=85&p=1
any chance you put the disc in backwards or dont have the throwout bearing correctly attached to the fork?
