The clutch fades as you drive, like pushing the pedal down doesnt disengage the clutch all the way and then sometimes it moves the clutch fine? Am i looking at air in my lines or do i gotta replace the clutch master cylinder?
Most likely it is contaminates or air in the system. I would fluch out the lines and cylinders with fresh fluid and bleed them. If it still does it it could be the slave cylinder on the transaxle.
