s10 warrior
its 1984 fiero, 4 banger with a 4spd. 47K miles.
my mom bought it and it started having problems where it'd grind when shifting gears.. so she took it to a shop.. they charged her $700 , and said they replaced the clutch ,resurfaced the flywheel,charged her for a clutch spring kit,shift for ... blah blah blah... they never did nothing like that
from what i see, no bolts have been removed to do a job like that,cuz they woulda broke cuz they so rusty! also the axel seals are in need of being replaced,so why didnt they just do that when the transmission was already out of the car? once again, they didnt do what they said.
all they did was replace the clutch master and bleed it !
after that it drove fine,and then started messing up ... the engine has to rev up a lot to get it rolling ,and the shift light tells u to shift up in to next gear when its barely rolling, wont go over 30 mph,motor is screaming just to stay at 20 mph... i think the clutch is slipping cuz its worn out.
the clutch pedal is fine, its not worn out and free of play,the clutch pedal sits up 1in higher than the brake pedal.
you can shift the transmission in to other gears with out grinding..
we got papers and reciepts from the shop charging her for the "clutch job"..
is there anything else to look at before i go buy a clutch kit and do it myself ?
