clutch problems
rise474
so my car is shooting up in rpm's but the engine is keeping up with it, then it smells like clutch. im guessing thats the presure plate. (opinions)
The next problem im having is a really bad lag with the car, in all the gears. idk if this has anything to do with the clutch problem. ive been told that i could be having really bad spark plug fouls because causeing it. Could oil foulers stop it?
If your clutch/pressure plate are worn, it will lag in all gears because the clutch is slipping.
You need a new clutch and pressure plate.
